Question / Help Recording does nothing
Triscy
So I've been trying out the 64 bit version of OBS on my Windows 7 PC. It's looking really good, but recording seems to do... absolutely nothing. Oddly enough it definitely is using the CPU whenever I enable recording, as I just did a test cast and it was a noticeable difference between the recording being started and stopped as far as CPU percentage, but no file is being made whatsoever. Not even a temporary file that just gets deleted when I end recording.
  • 2015-03-29 20-36-52.txt
Sapiens
Forum Moderator
20:36:57: [flv output: 'adv_file_output'] Writing FLV file 'E:/Users/Triscy/Videos/2015-03-29 20-36-57.flv'...
Have you looked there? It should open when you select File > Open Recordings.
Triscy
Well that's what happened. It wasn't changing the directory like I asked it to.
Now it did. Thanks.
