Question / Help PS4 Stream on Youtube and twitch lag when streaming
B_Rich
Hi i want to stream through my elgato HD60 with OBS onto Youtube when i try to stream the stream lags my OBS or ps4 do not.
Can someone please tell me what it is? is it my PC is it my internet connection please help!
My log is:
17:42:28.250: CPU Name: AMD A10-7300 Radeon R6, 10 Compute Cores 4C+6G
17:42:28.251: CPU Speed: 1896MHz
17:42:28.251: Physical Cores: 4, Logical Cores: 4
17:42:28.251: Physical Memory: 7114MB Total, 4860MB Free
17:42:28.251: Windows Version: 10.0 Build 17134 (revision: 112; 64-bit)
17:42:28.251: Running as administrator: false
17:42:28.251: Aero is Enabled (Aero is always on for windows 8 and above)
17:42:28.251: Windows 10 Gaming Features:
17:42:28.251: Game DVR: On
17:42:28.267: Sec. Software Status:
17:42:28.270: Windows Defender Antivirus: enabled (AV)
17:42:28.273: Windows Firewall: enabled (FW)
17:42:28.275: Windows Defender Antivirus: enabled (ASW)
17:42:28.276: Portable mode: false
17:42:28.599: OBS 21.1.2 (64bit, windows)
17:42:28.599: ---------------------------------
17:42:28.625: ---------------------------------
17:42:28.625: audio settings reset:
17:42:28.625: samples per sec: 44100
17:42:28.625: speakers: 2
17:42:28.627: ---------------------------------
17:42:28.627: Initializing D3D11...
17:42:28.627: Available Video Adapters:
17:42:28.629: Adapter 1: AMD Radeon(TM) R6 Graphics
17:42:28.629: Dedicated VRAM: 1058631680
17:42:28.629: Shared VRAM: 3729920000
17:42:28.629: output 1: pos={0, 0}, size={1366, 768}, attached=true
17:42:28.629: output 2: pos={1366, -256}, size={1280, 1024}, attached=true
17:42:28.633: Loading up D3D11 on adapter AMD Radeon(TM) R6 Graphics (0)
17:42:28.651: D3D11 loaded successfully, feature level used: 45056
17:42:30.433: ---------------------------------
17:42:30.433: video settings reset:
17:42:30.433: base resolution: 1366x768
17:42:30.433: output resolution: 1024x576
17:42:30.433: downscale filter: Bicubic
17:42:30.433: fps: 30/1
17:42:30.433: format: NV12
17:42:30.433: YUV mode: 601/Partial
17:42:30.435: Audio monitoring device:
17:42:30.435: name: Standaard
17:42:30.435: id: default
17:42:30.435: ---------------------------------
17:42:30.438: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
17:42:30.444: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:42:32.314: [AMF] The AMF Runtime is very old and unsupported, consider updating your drivers.
17:42:32.315: [AMF] Version 2.3.3 loaded (Compiled: 1.4.7.0, Runtime: 1.4.2.0, Library: 1;4;2;0;17.10.2001.1010;201710040227;CL#1466159).
17:42:32.406: [AMF] <Id: 1> Unable to create H264/AVC encoder, error AMF_ENCODER_NOT_PRESENT (code 36)
17:42:32.445: [AMF] <Id: 2> Unable to create H265/HEVC encoder, error AMF_FAIL (code 1)
17:42:32.490: [AMF] <Id: 3> Unable to create H264/AVC encoder, error AMF_ENCODER_NOT_PRESENT (code 36)
17:42:32.543: [AMF] <Id: 4> Unable to create H265/HEVC encoder, error AMF_FAIL (code 1)
17:42:32.543: [AMF] [H264/AVC] Not supported by any GPU, disabling...
17:42:32.543: [AMF] [H265/HEVC] Not supported by any GPU, disabling...
17:42:32.582: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
17:42:32.583: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': (null) (127)
17:42:32.583: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
17:42:32.584: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
17:42:32.594: [browser_source: 'Version: 1.31.0']
17:42:32.604: LoadLibrary failed for 'nvEncodeAPI64.dll': (null) (126)
17:42:33.619: Couldn't find VLC installation, VLC video source disabled
17:42:33.635: No blackmagic support
17:42:33.720: ---------------------------------
17:42:33.721: Loaded Modules:
17:42:33.721: win-wasapi.dll
17:42:33.721: win-mf.dll
17:42:33.721: win-dshow.dll
17:42:33.721: win-decklink.dll
17:42:33.721: win-capture.dll
17:42:33.721: vlc-video.dll
17:42:33.721: text-freetype2.dll
17:42:33.721: rtmp-services.dll
17:42:33.721: obs-x264.dll
17:42:33.721: obs-vst.dll
17:42:33.721: obs-transitions.dll
17:42:33.721: obs-text.dll
17:42:33.721: obs-qsv11.dll
17:42:33.721: obs-outputs.dll
17:42:33.721: obs-filters.dll
17:42:33.721: obs-ffmpeg.dll
17:42:33.721: obs-browser.dll
17:42:33.721: image-source.dll
17:42:33.721: frontend-tools.dll
17:42:33.721: enc-amf.dll
17:42:33.721: coreaudio-encoder.dll
17:42:33.721: ---------------------------------
17:42:33.721: ==== Startup complete ===============================================
17:42:33.795: All scene data cleared
17:42:33.796: ------------------------------------------------
17:42:33.914: WASAPI: Device 'Luidsprekers (High Definition Audio-apparaat)' initialized
17:42:34.011: WASAPI: Device 'Microfoon (High Definition Audio-apparaat)' initialized
17:42:34.022: adding 92 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
17:42:34.048: Switched to scene 'Scène'
17:42:34.081: ------------------------------------------------
17:42:34.081: Loaded scenes:
17:42:34.081: - scene 'Scène':
17:42:34.081: - source: 'Video opname-apparaat 2' (dshow_input)
17:42:34.081: - source: 'Browser' (browser_source)
17:42:42.629: AutoUpdateThread::run: Failed to fetch manifest file: Empty reply from serve
17:42:49.027: ---------------------------------
17:42:49.027: [DShow Device: 'Video opname-apparaat 2'] settings updated:
17:42:49.027: video device: Elgato Game Capture HD
17:42:49.027: video path: __elgato
17:42:49.027: resolution: 1280x720
17:42:49.027: fps: 30,00 (interval: 333333)
17:42:49.027: format: UYVY
17:42:50.720: using video device audio: yes
17:42:50.720: sample rate: 0
17:42:50.720: channels: 0
17:42:50.720: audio type: DirectSound
17:44:05.170: ---------------------------------
17:44:05.170: video settings reset:
17:44:05.170: base resolution: 1366x768
17:44:05.170: output resolution: 1024x576
17:44:05.170: downscale filter: Bicubic
17:44:05.170: fps: 60/1
17:44:05.170: format: NV12
17:44:05.170: YUV mode: 601/Partial
17:44:05.227: Settings changed (stream 1, video)
17:44:05.227: ------------------------------------------------
17:44:07.019: ---------------------------------
17:44:07.019: [x264 encoder: 'streaming_h264'] preset: ultrafast
17:44:07.032: [x264 encoder: 'streaming_h264'] settings:
17:44:07.032: rate_control: CBR
17:44:07.032: bitrate: 2500
17:44:07.032: buffer size: 2500
17:44:07.032: crf: 0
17:44:07.032: fps_num: 60
17:44:07.032: fps_den: 1
17:44:07.032: width: 1024
17:44:07.032: height: 576
17:44:07.032: keyint: 120
17:44:07.032:
17:44:07.067: ---------------------------------
17:44:07.109: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:44:07.109:
17:44:07.264: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://a.rtmp.youtube.com/live2...
17:44:07.306: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
17:44:07.544: [rtmp stream: 'adv_stream'] Connection to rtmp://a.rtmp.youtube.com/live2 successful
17:44:07.571: ==== Streaming Start ===============================================
17:47:52.209: [rtmp stream: 'adv_stream'] User stopped the stream
17:47:52.209: Output 'adv_stream': stopping
17:47:52.209: Output 'adv_stream': Total frames output: 13470
17:47:52.209: Output 'adv_stream': Total drawn frames: 13470 (13497 attempted)
17:47:52.209: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 27 (0,2%)
17:47:52.230: warning: 2 frames left in the queue on closing
17:47:52.234: ==== Streaming Stop ================================================
B_Rich
here are 3 more logs of the lag
  • 2018-06-19 21-31-08.txt
  • 2018-06-19 21-36-14.txt
  • 2018-06-19 17-39-47.txt
