pixel stream quality
Twepz1
Hello, i am really new to the forum and things but whenever i google my problem it sends to this site, but since i couldn't find solution for myself posting a post, i was trying to stream on Twitch while the picture on the stream was very blurry and pixelized.
  • 2021-06-03 20-22-48.txt
qhobbes
1. Your audio devices has a sample rate that doesn't match the OBS sample rate. This can result in audio drift over time or sound distortion. Check your audio devices in Windows settings (both Playback and Recording) and ensure the Default Format (under Advanced) is consistent. 48000 Hz is recommended.
OBS Sample Rate: 48000 Hz
BM-800 (High Definition Audio Device): 44100 Hz
2. Having the YUV Color range set to "Full" will cause playback issues in certain browsers and on various video platforms. Shadows, highlights and color will look off. In OBS, go to "Settings -> Advanced" and set "YUV Color Range" back to "Partial".
3. SLI/Crossfire Capture Mode (aka 'Shared memory capture') is very slow, and only to be used on SLI & Crossfire systems.
4. Your log contains no streaming session. Results of this log analysis are limited. Please post a link to a clean log file.
1) Restart OBS.
2) Start your stream for at least 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your stream.
