PC random freeze when streaming League of Legends after a match finished.
VegasC
I've seen a lot people reporting this issue but no final solution whatsoever.
Symptom:
Stream League, after a match finished, sometimes, the whole PC just freezes, no audio, have to force shutdown.
I've tried:
  • Disable HAGS: no luck
  • Swap test GPU (3080Ti, 4080): no luck
  • Swap test RAM: no luck
  • DDU: no luck
  • Disable any OC/UV: no luck
  • Run OBS with admin: no luck
  • Use dGPU to game and iGPU to stream: no luck
  • Use iGPU only, to game and stream (remove the dGPU completely): no issue
Logs and crash reports are attached.
  • crashes.zip
BustaChimez
Im having the same issue! Only crashes with League of Legends when leaving a match.
I have hardware accel turned off on Windows 10 and no fix :( I cant find a single solution.
