PC CRASHING THROUGH OBS
Hydrahz
So i stream a little.i run a dual PC setup with more than capable specs. Problem is when in OBS i try to add cameras to the scene the entire PC crashes, it straight cuts off turns back on and freezes. i have to flip the switch on the psu to reset the pc. i use a nzxt hd60 to send everything over, i recently before used an Elgato HD60 PrO instead. I yield the same results no matter waht i do or change. Ive been fighting this for literally like a year and a half, someone... im beggin help... i attached my 2 most recent logs from the crashing.
  • 2023-08-24 18-04-14.txt
  • 2023-08-24 18-02-52.txt
qhobbes
Are you able to access the input using the Windows Camera app with either of those devices without your computer crashing?
Hydrahz
I went ahead and tried, I CAN use 3 separate cameras AND the NZXT HD60 in Windows Camera App WITHOUT crashing the computer.
qhobbes
In OBS create a new Scene Collection. Leave it empty. Close OBS and other running programs. Open OBS so it starts with the empty Scene Collection and add the NZXT HD60.
Hydrahz
i have done that. Obs WILL run, will NOT crash the pc at all.
i then closed OBS, plugged in the 2 cameras into ubs 3.1 slots on my mobo: It works. i restart OBS. it crashes pc upon startup of OBS.
