OMTPlugin
OMTPlugin 1.0.0.9
omtdev
omtdev submitted a new resource:
OMTPlugin - Open Media Transport protocol plugin for Audio/Video over LAN
Send and receive high quality audio/video between OBS and other OMT compatible devices over a local network!
For more information about Open Media Transport in general, see the README here: https://github.com/openmediatransport/
OMT Source​
Receive audio/video from OMT sources on the network.
Supports HDR workflows using the Color Space dropdown in the OMT Source properties.
OMT Output​
Send audio/video from the main OBS output.
This...
阿斯顿
OBS 31.1.2 crashes immediately upon launch.
  • Crash 2025-09-03 11-52-35.txt
omtdev
We cannot replicate this issue, so there appears to be a problem with that particular computer or the settings being used.
Are you able to test on another machine?
Hello!
Was just testing out the plugin for my own workflow. I had a couple of questions:
I tend to use 59.94fps (keeps with NTSC/ATSC standards) internally as well as on-stream as opposed to a full 60fps. Does this cause any issues? It seems to work, but it could be smoother. I could set up a secondary profile set to 60fps on the three systems I was testing on, which are part of my production setup, but this is a lower-priority item presently.
Additionally, the plugin seems to work well with a need I have for the BGRA colorspace. I am a VTuber which makes it ideal for me to send a stream with an alpha channel to another computer for integration into my stream.
Finally, I found out how to properly get this plugin working in the C:\ProgramData\obs-studio\plugins hierarchy. I needed to make sure the plugin directory was correctly named and it shows up. However, it will not send any stream out. I have not yet tried to see if it can receive in this way. Any plans to get this working this way?
Thanks for any information you might have!
--Katt. =^.^=
