Occasional 300-700 frames of rendering/encoding lag from encoding overload with game freeze
BinksMagnus
I have an ongoing issue where occasionally, unpredictably, in many games, a game I'm playing will freeze and any recording I'm making will miss frames due to rendering/encoding lag, accompanied by an encoding overload message. I do not miss frames basically ever aside from that and generally have low CPU and memory utilization when using streaming/recording even at high quality. This only seems to happen when I'm recording so I'm trying to rule out or identify causes. This problem has persisted through multiple driver installs including removing old drivers with DDU.
The problem occurred at around 2202 in the attached OBS log file but the log does not note any actions at that time. Attached DxDiag in case that is helpful.
  • 2025-07-09 21-04-07.txt
  • DxDiag.txt
