OBS Won't Stop Recording [02/06/2025]
MitoGouken
Hello OBS Support Team,
I've been using OBS with the same configuration for a long time. However, after upgrading my PC to a more powerful setup optimized for streaming, I encountered an issue where I can't stop the recording anymore.
Previous Setup:
  • GPU: GTX 1070 Ti
  • CPU: Ryzen 5 3600X
  • RAM: 16GB
  • Storage: SSD
Current Setup:
  • GPU: RTX 3070 Ti
  • CPU: Intel i9-13900K
  • RAM: 32GB
  • Storage: M.2 SSD
With my old setup, I was able to record in 4K at 60 FPS without any issues—I could stream and record simultaneously without problems.
Now, despite the significant hardware upgrade, everything works fine while streaming: I click “Start Streaming” and “Stop Streaming,” and it functions perfectly. However, recording doesn’t stop properly.
I’ve tested various settings:
  • Different recording formats (MP4, MKV, FLV, etc.)
  • Lowering resolution to 1080p
  • Changing other encoding options
Nothing resolves the issue. When I attempt to stop the recording, the program freezes and doesn’t close properly. It generates an extremely small file, but when I copy and paste the file elsewhere, the full recording appears and plays correctly.
Additionally, when I edit these recordings in Filmora, a 30-minute video sometimes shows up as 2 hours long, which is very confusing.
Additional Information:
Please check this video I recorded showing the issue. The recording completes, but OBS doesn't close properly. When I force close it, the program crashes. Then, I go to Task Manager, delete the process OBS-FFMPEG-MUX, and magically, the file completes as expected—something that OBS itself fails to do. The resulting file works perfectly, even for editing.
This cannot be a CPU overload issue—I have an i9-13900K, which is far more powerful than a Ryzen 5 3600X, and I don’t even use the CPU for recording—I rely entirely on my GPU. I have also tried with another GPU on the same setup, and the issue persists.
Honestly, I've tried everything—checked forums, followed all recommendations, and still, nothing works. I strongly believe this issue is not on my end, but rather a bug in OBS during the export process.
Could you please investigate this?
MitoGouken
Well, after struggling a lot and ALONE I ended up discovering the cause of all the problems
I used a Logitech webcam and was using the Logitune software, I just had to uninstall it and everything went back to normal
I hope this helps you who are going through this problem!
kodino
yeap.. its work for me too. im two times reinstal windows and all drivers app (Logitune also lol) and cant stop record..
delete Logitune - and REC work greatr again/
Thanks Mito
Ohhh geeeez!!!! I have been trying to figure out for months why I was having the same issue. I looked at other options, updating, and doing everything that you had said you did that didn't work. I then deleted Logitune after reading both postings from you guys, and of course NOW it starts working. Thanks guys for the help!
Suslik V
@The Future Engineer
There is info that a newer version (update) of the software from the Logitech fixes the problem:
It was mentioned here that an older version of the Logi Tune free of this problem:
Here is some tech details:
So, only some versions of the software interfere with OBS.
