Question / Help OBS White screen
willis12rus
I use many ways to fix this bug(reinstall nvidia drivers, use compatibility options, use integrated card(intel hd), use old versions), but i can't fix this bug.
Here are logs:
  • 2020-03-14 10-21-46.txt
You haven't added any sources.
10:21:50.276: WASAPI: Device 'Динамики (Realtek High Definition Audio)' initialized
10:21:50.293: [WASAPISource::TryInitialize]:[Микрофон (USB Audio Device)] Failed to get initialize audio client: 8889000A
10:21:50.293: [WASAPISource::WASAPISource] Device 'default' not found. Waiting for device
10:21:50.293: Switched to scene 'Сцена'
10:21:50.293: Failed to glob scene collections
10:21:51.219: [rtmp-services plugin] Successfully updated file 'services.json' (version 124)
10:21:51.220: [rtmp-services plugin] Successfully updated package (version 124)
You need to add display, game, or window captures to OBS in order to see a picture.
Try running as admin, or use display capture. There have been persistent issues with game capture and LoL.
willis12rus
