OBS Studio randomly disconnect
JanusLauvring
Happend a lot lately with disconnecting even though the internet works fine and is 1000/1000 mbps.
I may see the problem in the log? but the Log makes no sense to me, im not an expert?
is there anyone that can help checking the log?
After a few attempts reconnecting it normally reconnects....
  • 2024-09-02 23-42-13.txt
There's no ouput session on the log.
14 plugins are too many. Remove the ones you don't need or are outdated / not compatible with OBS 30.2.x
Update the ones that you do use and make sure are compatible with OBS 30.2.x
Same with scripts.
