Question / Help OBS Studio Low-End Laptop Streaming Best settings?
Mikael Day
Hi so i'm running a Samsung Gamer Series 7
(Pictures on the bottom.)
and i wonder what the best settings for my Stream is?
currently able to run 853x480 downscale with 30FPS on 650 Bitrate without problems but the stream no matter the game is heavely pixleated, i have 1.07mbps in up-speed
here is my logfile as well...
12:23:00.752: CPU Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
12:23:00.752: CPU Speed: 2195MHz
12:23:00.752: Physical Cores: 4, Logical Cores: 8
12:23:00.752: Physical Memory: 16365MB Total, 10904MB Free
12:23:00.752: Windows Version: 10.0 Build 16299 (revision: 248; 64-bit)
12:23:00.752: Running as administrator: true
12:23:00.752: Aero is Enabled (Aero is always on for windows 8 and above)
12:23:00.752: Windows 10 Gaming Features:
12:23:00.752: Game Bar: On
12:23:00.752: Game DVR: On
12:23:00.752: Game DVR Background Recording: Off
12:23:00.754: Sec. Software Status:
12:23:00.776: Windows Defender Antivirus: enabled (AV)
12:23:00.776: Windows-brandväggen: enabled (FW)
12:23:00.776: Windows Defender Antivirus: enabled (ASW)
12:23:00.777: Portable mode: false
12:23:00.807: OBS 21.0.1 (64bit, windows)
12:23:00.807: ---------------------------------
12:23:00.820: ---------------------------------
12:23:00.820: audio settings reset:
12:23:00.820: samples per sec: 48000
12:23:00.820: speakers: 2
12:23:00.821: ---------------------------------
12:23:00.821: Initializing D3D11...
12:23:00.821: Available Video Adapters:
12:23:00.823: Adapter 1: AMD Radeon HD 6900M Series
12:23:00.823: Dedicated VRAM: 2134573056
12:23:00.823: Shared VRAM: 4026531840
12:23:00.823: output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:23:00.825: Loading up D3D11 on adapter AMD Radeon HD 6900M Series (0)
12:23:00.832: D3D11 loaded successfully, feature level used: 45056
12:23:01.760: ---------------------------------
12:23:01.760: video settings reset:
12:23:01.760: base resolution: 1920x1080
12:23:01.760: output resolution: 852x480
12:23:01.760: downscale filter: Bicubic
12:23:01.760: fps: 30/1
12:23:01.760: format: NV12
12:23:01.761: Audio monitoring device:
12:23:01.761: name: Default
12:23:01.761: id: default
12:23:01.762: ---------------------------------
12:23:01.763: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
12:23:01.764: LoadLibrary failed for '../../obs-plugins/64bit/CLRHostPlugin.dll': The specified module could not be found.
12:23:01.764: (126)
12:23:01.764: Module '../../obs-plugins/64bit/CLRHostPlugin.dll' not loaded
12:23:01.766: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:23:01.768: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
12:23:01.768: Failed to initialize module 'enc-amf.dll'
12:23:01.781: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
12:23:01.782: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
12:23:01.782: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
12:23:01.783: Failed to load 'en-US' text for module: 'obs-browser.dll'
12:23:01.783: [browser_source: 'Version: 1.29.0']
12:23:01.785: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
12:23:01.785: (126)
12:23:01.914: Couldn't find VLC installation, VLC video source disabled
12:23:01.916: No blackmagic support
12:23:01.927: ---------------------------------
12:23:01.927: Loaded Modules:
12:23:01.927: win-wasapi.dll
12:23:01.927: win-mf.dll
12:23:01.927: win-ivcam.dll
12:23:01.927: win-dshow.dll
12:23:01.927: win-decklink.dll
12:23:01.927: win-capture.dll
12:23:01.927: vlc-video.dll
12:23:01.927: text-freetype2.dll
12:23:01.927: rtmp-services.dll
12:23:01.927: obs-x264.dll
12:23:01.927: obs-vst.dll
12:23:01.927: obs-transitions.dll
12:23:01.927: obs-text.dll
12:23:01.927: obs-qsv11.dll
12:23:01.927: obs-outputs.dll
12:23:01.927: obs-filters.dll
12:23:01.927: obs-ffmpeg.dll
12:23:01.927: obs-browser.dll
12:23:01.927: image-source.dll
12:23:01.927: frontend-tools.dll
12:23:01.927: enc-amf.dll
12:23:01.927: coreaudio-encoder.dll
12:23:01.927: ==== Startup complete ===============================================
12:23:01.936: All scene data cleared
12:23:01.936: ------------------------------------------------
12:23:01.988: WASAPI: Device 'VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)' initialized
12:23:02.020: WASAPI: Device 'VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)' initialized
12:23:02.042: WASAPI: Device 'VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)' initialized
12:23:03.144: [window-capture: 'Window Capture'] update settings:
12:23:03.144: executable: Discord.exe
12:23:03.558: Switched to scene 'Stream'
12:23:03.558: ------------------------------------------------
12:23:03.558: Loaded scenes:
12:23:03.558: - scene 'Game':
12:23:03.558: - source: 'Game Capture' (game_capture)
12:23:03.558: - filter: 'Render Delay' (gpu_delay)
12:23:03.558: - source: 'Music Player' (text_gdiplus)
12:23:03.558: - filter: 'Scroll' (scroll_filter)
12:23:03.558: - source: 'Video Capture Device 2' (dshow_input)
12:23:03.558: - filter: 'Chroma Key 2' (chroma_key_filter)
12:23:03.558: - filter: 'Chroma Key' (chroma_key_filter)
12:23:03.558: - filter: 'Image Mask/Blend' (mask_filter)
12:23:03.558: - filter: 'Color Correction' (color_filter)
12:23:03.558: - scene 'Life Is Strange Ep.4 with Dayeanne':
12:23:03.558: - source: 'Image 7' (image_source)
12:23:03.558: - source: 'Image 9' (image_source)
12:23:03.558: - source: 'Stream Chat' (browser_source)
12:23:03.558: - source: 'Video Capture Device' (dshow_input)
12:23:03.558: - source: 'Image 8' (image_source)
12:23:03.558: - source: 'Display Capture' (monitor_capture)
12:23:03.558: - source: 'Window Capture' (window_capture)
12:23:03.559: - filter: 'Render Delay' (gpu_delay)
12:23:03.559: - source: 'Game Capture' (game_capture)
12:23:03.559: - source: 'Stream overlay' (image_source)
12:23:03.559: - source: 'Discord Voice Chat' (browser_source)
12:23:03.559: - filter: '200' (gpu_delay)
12:23:03.559: - source: 'Music Player' (text_gdiplus)
12:23:03.559: - filter: 'Scroll' (scroll_filter)
12:23:03.559: - source: 'Viewer counter' (browser_source)
12:23:03.559: - source: 'Follow Alert' (browser_source)
12:23:03.559: - source: 'Donation Alert' (browser_source)
12:23:03.559: - source: 'Image 10' (image_source)
12:23:03.559: - source: 'Donation Goal' (browser_source)
12:23:03.559: - source: 'To Donate' (text_gdiplus)
12:23:03.559: - source: 'Image 2' (image_source)
12:23:03.559: - source: 'Hole to another universe' (image_source)
12:23:03.559: - source: 'All seeing eye' (image_source)
12:23:03.559: - source: 'Fire Walk' (image_source)
12:23:03.559: - source: 'Poker Face' (image_source)
12:23:03.559: - source: 'Max Camera' (image_source)
12:23:03.559: - source: 'Kate' (image_source)
12:23:03.559: - source: 'Blue Butterfly' (image_source)
12:23:03.559: - source: 'BrowserSource 2' (browser_source)
12:23:03.559: - scene 'Stream LIS Starting soon':
12:23:03.559: - source: 'Image' (image_source)
12:23:03.559: - source: 'Countdown' (text_gdiplus)
12:23:03.559: - source: 'Time till live time count' (text_gdiplus)
12:23:03.559: - scene 'Credits':
12:23:03.559: - source: 'BrowserSource' (browser_source)
12:23:03.559: - scene 'Issue test':
12:23:03.559: - scene 'Subnautica':
12:23:03.559: - source: 'Video Capture Device 2' (dshow_input)
12:23:03.559: - filter: 'Chroma Key 2' (chroma_key_filter)
12:23:03.559: - filter: 'Chroma Key' (chroma_key_filter)
12:23:03.559: - filter: 'Image Mask/Blend' (mask_filter)
12:23:03.559: - filter: 'Color Correction' (color_filter)
12:23:03.559: - source: 'Image 3' (image_source)
12:23:03.559: - source: 'Stream Chat' (browser_source)
12:23:03.559: - scene 'KCD':
12:23:03.559: - source: 'KCD Overlay' (image_source)
12:23:03.559: - scene 'Stream':
12:23:03.559: - source: 'Image 4' (image_source)
12:23:03.559: - source: 'Text (GDI+)' (text_gdiplus)
12:23:03.559: - source: 'Text (GDI+) 2' (text_gdiplus)
12:23:03.559: ------------------------------------------------
12:23:03.825: Video Capture Device 2: data.GetDevice failed
12:23:03.825: Video Capture Device 2: Video configuration failed
12:36:18.452: Settings changed (outputs)
12:36:18.452: ------------------------------------------------"
  • 2018-03-01 12-23-00.txt
