OBS Studio Crash Unhandled exception: c0000005 Fault address: 200000018 ((null))
Erkfps
i've justed alt tab and the obs crashed, when i tried to open again, does crashed again and again.
  • Crash 2022-04-14 14-21-49.txt
  • Crash 2022-04-15 05-17-06.txt
  • Crash 2022-04-15 05-19-36.txt
  • Crash 2022-04-15 05-19-49.txt
  • Crash 2022-04-15 05-22-41.txt
wilderf353
Maybe something in global.ini is loading something that is corrupt?
1) Go to C:\Users\<your folders>\AppData\Roaming\obs-studio
2) rename the file global.ini -> xglobal.ini
3) try running OBS ... it will create a new global.ini file.
Also, are there any new log files in C:\Users\<your folders>\AppData\Roaming\obs-studio\logs?
