OBS Stops working My stream goes offline and you can't stop the Stream from OBS
Rashomonk
When I stream after 2 hours my stream stops and my viewers are the ones noticing the issue first, then my FPS = 0 and my OBS says my stream is up and running, I have to terminate the process through the task manager because the app stops responding.
I check my stream with the Twitch bandwidth test app and I have a wired connection.
  • 2020-12-04 17-48-29.txt
  • 2020-12-04 20-17-27.txt
