Question / Help OBS Stopped working after update (OBS 24.0.2 to OBS 24.0.3)
syri
So OBS was always working fine until today I just updated OBS. After the update, OBS stopped working completely. Now, I cannot record or stream anything. The error says
'Starting the output failed. Please check the log for details. Note: If you are using the NVENC or AMD encoders, make sure your video drivers are up to date.'
The logs are the file attached.
  • 2019-11-04 18-09-39.txt
Is your Nvidia driver up to date?
18:11:33.706: error: Driver does not support the required nvenc API version. Required: 9.0 Found: 8.0
18:11:33.706: error: The minimum required Nvidia driver for nvenc is 390.77 or newer
18:11:33.709: [NVENC encoder: 'simple_h264_stream'] Failed to open NVENC codec: Function not implemented
18:11:33.709: Stream output type 'rtmp_output' failed to start!
