OBS "Skipped Frames Due to Encoding Lag"
Kansei Dorifto
Could someone assist me with a problem i'm facing in OBS
MY PC
AMD Ryzen 7 7700 8-Core Processor
16,0 GB RAM
  • 2024-01-14 21-58-45.txt
rockbottom
Disable HAGS, your PC will need to be re-started.
No overload on the 3070, but run your LG monitor @ 120HZ when using OBS. You will more than likely have some stuttering with it set @ 144.
Only (1) Display/Game/Window capture per Scene. Move one of them to a New Scene.
21:58:46.967: - scene 'Scena':
21:58:46.967: - source: 'hyper' (wasapi_input_capture)
21:58:46.967: - filter: 'Equalizzatore tri-banda' (basic_eq_filter)
21:58:46.967: - filter: 'Espansore' (expander_filter)
21:58:46.967: - filter: 'Compressore' (compressor_filter)
21:58:46.967: - filter: 'Limitatore' (limiter_filter)
21:58:46.967: - filter: 'Riduzione del rumore' (noise_suppress_filter_v2)
21:58:46.967: - filter: 'Sensibilità d'ingresso' (noise_gate_filter)
21:58:46.967: - source: 'Cattura gioco' (game_capture)
21:58:46.967: - source: 'Cattura audio d'applicazione' (wasapi_process_output_capture)
21:58:46.967: - source: 'Cattura schermo' (monitor_capture)
21:58:46.967: - source: 'Cattura audio applicazioni (BETA)' (wasapi_process_output_capture)
rockbottom
When you set-up NVENC, do not check the Re-scale Output box.
22:23:41.226: encoder 'advanced_video_recording': Scaled resolution matches output resolution, scaling disabled
rockbottom
NVENC H265 settings for 2160p to get you started. Adjust as needed & for H264.
