OBS program window problems
BearAttaxx
Hello people,
I have the following problem
I have 3 monitors
1x left 23.8 inch
1x middle 42 inch
1x right 23.8 inch
both 23.8 inch monitors are adjusted to the 42 inch in portrait format, that was never a problem for the setup until the latest update
now to the problem
I start OBS and adjust the window to the left monitor, so snap to the total size of the screen (1080x1920)
now I press start stream and from there my problem begins
when I press start stream, OBS simply changes its program window size to 1440 x1080, for whatever reason and I can't get it to the monitor anymore without parts of the window being cut off so that I can see the entire OBS including my task arranged in OBS
is there a way to tell OBS not to change from its adjusted size 1080×1920 size can vary? I don't know what to do anymore, help.
I've included a picture in the post, maybe it will help to illustrate my problem
sorry for my bad English
