Question / Help OBS Not Responding on Startup
Feuzaed
Any time I try to open OBS, it has a white screen for a couple of seconds before it stops responding and I have to force close it via task manager. I've tried reinstalling, restarting, shutting down all programs, turning off all antivirus software, but no matter what I do the results stay the same. I used to use OBS frequently several months ago with no issues whatsoever, but now it's giving me a hassle. I've also tried to look for forums with the same issue as mine but while some are similar, I've tried their solutions and they didn't fix my problem.
The log file attached is one when no antivirus software is closed.
Thanks in advance!
  • 2019-03-02 11-54-10.txt
Feuzaed
Update: Finally got it to work. I uninstalled the x64 bit version I had installed, installed the x32 bit version and afterward reinstalled the x64 bit version again, restarted my computer, and it worked :P
