Question / Help obs keeps crashing
kerbzy
so recently my obs has been crashing like crazy on Nvenc and the other one it crashes less in NCENC
its a dual pc streaming setup
iv done temp tests and every thing looks good 50 to 60s for gpu
game DVR is off and the build is a i9700x ,gtx 1060 ,32 gb ram 1tb
iv updated obs and windows still having the same problem
  • Crash 2019-02-11 15-52-21.txt
carlmmii
You're on an old version of OBS. That version of OBS's auto-updater is also broken, so you need to manually download the latest version.
Also... you should update windows. The October 2018 update should be available to you.
kerbzy
crashed again after updates
