OBS hits error when using hardware encoding(AMD)
Ryuuou
I get this error when I try using hardware encoding but the software encoding works fine. Even decent quality as well. Still I want to try hardware for a bit more. Dont know what the issue is really. Too old hardware or OS or why does this AMF error persist on hardware encoding. As the log file says I use version OBS 25.
  • 2025-03-09 13-23-25.txt
  • DxDiag.txt
Unfortunately, everything you use (hardware, OS, OBS, plugins) is obsolete and has been replaced long since. The knowledge how to deal with your kind of setup is also long gone. The only thing I can say about your setup is that you should try to acquire hardware that's able to run current software (Windows 11, OBS 31). Don't go for Windows 10, it's obsolete as well in half a year as well.
Development takes always place on current machines, and current hardware+software moves on. It's a huge workload in software development to continue to support old hardware and OS and at the same time integrate the new stuff from new hardware and OS.
There is always a time window where existing hardware is new and not yet supported, then well supported, then not well supported any more, then obsolete. If you choose to stay with some hardware and OS, you need to stay with the software from that time that can deal with it best. However, there are no updates to that any more, so if it doesn't work for whatever reason, there is no software fix to expect any more, and people who did know how to configure that software lose their memory as well, since they usually move on to newer software.
And in the end you're on your own if you stay with obsolete computer hardware and software. This is what has happened for your setup. It's the way things work these days. If you now "update" to Windows 10, you're in the same situation as you are now again in just half a year. That's not a wise thing to do.
Ryuuou
I did check that the gpu I use works with AMF but the issue seems to be something else. Not sure if its the driver version or OBS version. The latest driver it says and I have the latest driver as far as it goes on Win 7 but the term latest drivers may mean the latest that would be the shitty win 11.
