Bug Report Obs froze then crashed after 3 hours of streaming
xwidghet
After three hours and 20 minutes my stream went down, and when I went to check obs it was frozen. It sat there stuck for about a minute then I got the normal error box from windows letting me know that obs has stopped working. There is no crash file that I could find as the following folder is empty: C:\Users\user\AppData\Roaming\obs-studio\crashes.
However the following lines are at the bottom of my log file.
03:17:23: WriteN, RTMP send error 10053 (547 bytes)
03:17:23: WriteN, RTMP send error 10053 (79 bytes)
03:17:23: WriteN, RTMP send error 10038 (42 bytes)
  • 2015-07-11 22-49-43.txt
Lain
Forum Admin
Lain
Forum Moderator
Developer
Hm, looks like you got disconnected, and then something caused the stream to freeze. Actually I think I know what it is. Thanks for pointing it out. I'll see if I can get it fixed by next patch.
