Question / Help OBS does not detect any cameras
Craftica
Hi there
I am currently on the latest version of OBS, at the time of posting. I have a Genius Facecam 1000x and 2 generic cameras, but OBS does not detect any of them. They all work 100% fine with any other software. The cameras are on the latest drivers.
I use Kaspersky free AV, I have disabled it and my Windows firewall, but no luck.
Please assist, as I would like to stream with the camera
  • 2020-03-24 16-34-27.txt
Several possibilities:
1) You've selected a resolution/framerate those cameras do not support
2) Some other security feature or program is blocking access to the cameras
3) Some other app is accessing the camera, preventing OBS from accessing it.
16:34:35.085: Video Capture Device: DecodeDeviceId failed
16:34:35.085: Video Capture Device: Video configuration failed
16:34:35.090: Camera: DecodeDeviceId failed
16:34:35.090: Camera: Video configuration failed
Craftica
Thanks a ton for your reply. My dumb ass did not go check on the windows 10 settings for the camera.
Tip for others having this issue, under camera settings, enable desktop apps. It was disabled by default for some reason
