OBS crashing when launching
la_clo
Hi !
Since today, my OBS seems not to be able to launch properly, and it keeps saying the program is "not responding" a few second after. The program is kinda flickering before saying that.
I tried relaunching my PC and it does not help. I'm not the most skilled with computers so if you have an idea why it seems to happen, I'd appreciate some help.
  • 2025-07-17 19-02-47.txt
la_clo
OK I tried reinstalling the preceding version and I don't have this issue anymore so it seems that the latest version (31.1.1) is at fault.
You need to verify that each plugin you have installed is updated and compatible with the OBS version you are using.
When OBS crashes always produce a crash report. If no crash report is present after the crash then the cause of the forced close of OBS comes from a third party plugin or an incompatibility with an old driver that needs to be updated, or a third party app (program) which causes conflicts with OBS.
Minsnicterb
I have the same problem. I formatted and reinstalled it. The latest version is buggy. How did you manage to corrupt a version that was working properly?
