Obs Crashing on Shutdown
Dewdney
Obs Crashing on shutdown I assume its an issue with a plugin - but it has only been happening the last month or so
Im not sure though and was hoping someone else may have some insight
Does not affect the stream OBS seems to run fine for the first few hours and then its almost like a memory leak? When I go to shut it down after stream thats when It becomes super resource intensive and then crashes.
prgmitchell
Forum Moderator
Correct, it would be one of your third party plugins. Without a regular log I wouldn't know which you have installed.
prgmitchell
Forum Moderator
My Apologies here is the Other Log file
Lots of plugins, you'll have to take some time to trial-and-error troubleshoot and figure out which is the issue. I would recommend not using streamup to mass install plugins in the future, stick to ones you specifically use.
Dewdney
Haha I only use Streamup to keep things up to date those are all ones I use myself haha
gourbex
Hi, i have same problem. We have any solution for crash after close obs?
  • Crash 2025-05-11 21-29-52.txt
  • Crash 2025-05-16 14-01-15.txt
  • Crash 2025-05-17 00-45-15.txt
