OBS Crashing due to avcodec-61 and nvencodeapi64.dll
Wayne01
The first type of crash: nvencodeapi64.dll
Could you advice what to do? My OBS crashing due to nvencodeapi64.dll
Crash #3: Fault address: 7FFF753F5D10 (c:\windows\system32\nvencodeapi64.dll)
Crash report: https://obsproject.com/logs/aPnO72mwWySM2On3
Current log: https://obsproject.com/logs/04OthFDBdsPzupmC
Previous log: https://obsproject.com/logs/3TxgdG7iOqwsxROr
Second type of crash (happens very often): avcodec-61
Crashes 3-4: Jan 29
Crash #4:Fault address: 7FFF62E6E302 (a:\program files (x86)\00. obs portable\bin\64bit\avcodec-61.dll)
Crash report: https://obsproject.com/logs/H0Nm5Dg1pxiBO0k0
Current log: https://obsproject.com/logs/ZPANBxNmsajJOLcY
Previous log: https://obsproject.com/logs/ywLnyK8BonjBiq17
Crashes 2: Jan 27
Crash #2: Fault address: 7FF9D2BC3F87 (a:\program files (x86)\00. obs portable\bin\64bit\avcodec-61.dll)
Previous crash report: https://obsproject.com/logs/lxua3YNGkhryXLXO
Current log file: https://obsproject.com/logs/QpiVfK4ysrENVcGW
Previous log file: https://obsproject.com/logs/qXIg3eMB5O4BU7qa
Crashes 1: Jan 25
Crash #1: Fault address: 7FFD2A76CDB0 (a:\program files (x86)\00. obs portable\bin\64bit\avcodec-61.dll)
Crash report: https://obsproject.com/logs/DRkOwrRrd7MPQ1fe
Log file: https://obsproject.com/logs/VDiWmL5kAbBJkbKe
Current log file: https://obsproject.com/logs/N7UNmwfOgQBvXvOZ
I switched from FFMPEG audio to CoreAudio AAC, it was just fine.. but recently OBS started to crash again, quite often 2-3 times during the stream...
PS This avcodec-61.dll exist only here:
A:\Program Files (x86)\00. OBS Portable\bin\64bit
Raumen
Been having this problem recently too with avcodec-61.dll. I have no idea if any updates did it or what but it's annoying have to restart my stream 3-5 times per. :/
StarGoid
Can confirm... same problem here. Have been coping with it since late DEC2024. Causing major issues with my streams.
  • Crash 2025-02-23 18-19-50.txt
Suslik V
@StarGoid do you have media files in the scenes? Especially in .webm container (Stinger transition maybe)?
Similar thread:
StarGoid
Similar thread:
Thank you Very Much!!
I do have WebM assets. I'll see about removing those ASAP.
