OBS Crashes when i Updated and Closes it. It
EroNelly
Help me, its like it all started my OBS updated one day and it crashed. so i tried skip the update but when i close it, it crashed. But i can still stream. Im kinda worry if i keep using outdated OBS might ruin it. So did i do something wrong? HEre is my crash reports.
  • Crash 2022-11-06 22-54-42.txt
  • Crash 2022-11-07 00-52-24.txt
  • Crash 2022-11-07 22-00-02.txt
  • Crash 2022-11-07 22-06-07.txt
  • Crash 2022-11-08 00-27-46.txt
  • Crash 2022-11-15 21-54-19.txt
  • Crash 2022-11-16 01-41-15.txt
  • Crash 2022-11-18 01-49-50.txt
  • Crash 2022-11-29 01-20-02.txt
  • Crash 2022-11-30 02-08-30.txt
.norman.
crashes after exit are usually caused by a 3rd party plugin not closing properly. generally, these have little or no effect on the function of OBS. if OBS is crashing when you try and update via the update tool inside of OBS, you can always download the latest release from the download section of this page and update it that way. it will preserve all of your settings and scenes as well.
