OBS Crash on RTX 5060 (on 4070S no problem)
Dr2co
RTX 4070 Super was installed and there were no problems.
Installed RTX 5060 error starting obs
1. tried the very first driver (576.52) for 5060 and last (576.88)
2. I install back the RTX 4070 Super and there are no problems with starting obs
*I didn't change the scenes in the OBS and other stuff, everything is as I had it
Log crash attach to post
ps I think this is a global problem with the driver +RTX5000 and processing of scenes, photos, videos and other things in the OS
  • Crash 2025-07-01 19-23-14.txt
  • Crash 2025-07-01 19-13-32.txt
  • Crash 2025-07-01 18-34-41.txt
  • Crash 2025-07-01 18-59-05.txt
  • Crash 2025-07-01 18-23-26.txt
Suslik V
Unhandled exception: c0000005
libobs version: 31.0.3 (64-bit)
Thread 3200: tiny_tubular_task_thread (Crashed)
00000047298FFA70 00007FF8A9A14A49 0000000000000000 0000017541E50C40 000001754B38B320 00000173298E3AC2 w32-pthreads.dll!pthread_mutex_lock+0x59
00000047298FFAE0 00007FF86E4011AB 0000000000000000 0000017329825380 0000000000000010 0000017329825380 nv-filters.dll!nvidia_audio_destroy+0x2b
00000047298FFB20 00007FF8755E0C31 0000017329825380 0000017329825380 0000000000000400 00007FF8755E0BD0 obs.dll!obs_source_destroy_defer+0x61
00000047298FFB60 00007FF87561DE30 FFFFFFFFFFFFFFFF 00000047298FFC20 0000017329791E00 0000017329791E00 obs.dll!tiny_tubular_task_thread+0x440
00000047298FFBC0 00007FF8A9A11461 000001732971F7B0 0000000000000000 0000000000000000 0000000000000000 w32-pthreads.dll!ptw32_threadStart+0x171
00000047298FFC30 00007FF8E4571BB2 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ucrtbase.dll!0x7ff8e4571bb2
00000047298FFC60 00007FF8E4E47374 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff8e4e47374
00000047298FFC90 00007FF8E6CBCC91 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff8e6cbcc91
Thread 36A8: (Crashed)
000000F25178F510 00007FFC50D9745F 0000026100000000 000000007F800000 0000000000000000 00007FFC5ABB4AB7 obs.dll!obs_filter_get_parent+0x2f
000000F25178F540 00007FFC49162F24 000000F25178F739 0000026179AB97D0 0000000000000001 0000026179AB9120 nv-filters.dll!nvidia_audio_filter_audio+0x44
000000F25178F5D0 00007FFC50D9AA8C 000002617922F670 000000F25178F739 0000025F5B57EB90 0000025F5B57EB90 obs.dll!obs_source_output_audio+0x1ac
000000F25178F6B0 00007FFC36ED433E 0000025F000001E0 00000261000001E0 0000025F00000000 0000026181AF14B0 win-wasapi.dll!WASAPISource::ProcessCaptureData+0x26e
000000F25178F7A0 00007FFC36ED4969 0000025F61389A60 0000025F613A48D0 0000025F5B57EB90 0000025F61389A60 win-wasapi.dll!WASAPISource::OnSampleReady+0x19
000000F25178F7F0 00007FFC36ED15AD 0000025F61388550 0000025F613A50B0 0000025F61389830 0000025F61388550 win-wasapi.dll!WASAPISource::CallbackSampleReady::Invoke+0xd
000000F25178F820 00007FFC5A02147D 0000025F00000001 0000025F6E4A2E00 0000000000000000 00007FFC61060DAA rtworkq.dll!0x7ffc5a02147d
000000F25178F8A0 00007FFC61060EBC 0000025F6E4A2F88 000002618672AFC0 0000000000000000 000002618672B440 ntdll.dll!0x7ffc61060ebc
000000F25178F8F0 00007FFC6109D566 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffc6109d566
000000F25178FBF0 00007FFC60F57374 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffc60f57374
000000F25178FC20 00007FFC6109CC91 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffc6109cc91
Thread CEC: (Crashed)
000000253504F170 00007FFC5E7FC230 0000000041A00000 BAF9D352BB0204C3 0000000000000000 0000000000000000 ucrtbase.dll!0x7ffc5e7fc230
000000253504F1D0 00007FFC155B7286 0000017F00000000 000000007F800000 0000000000000000 00007FFC5ABD4AB7 obs.dll!brealloc+0x26
000000253504F200 00007FFC3344300A 000000253504F3F9 0000017FDA18EB70 0000000000000001 0000017FDA18E4C0 nv-filters.dll!nvidia_audio_filter_audio+0x12a
000000253504F290 00007FFC1559AA8C 0000017FD2105A10 000000253504F3F9 0000017DBD0F0AC0 0000017DBD0F0AC0 obs.dll!obs_source_output_audio+0x1ac
000000253504F370 00007FFC2E55433E 0000017D000001E0 0000017F000001E0 0000017D00000000 0000017FDA9D2890 win-wasapi.dll!WASAPISource::ProcessCaptureData+0x26e
000000253504F460 00007FFC2E554969 0000017DBD0F1070 0000017DBD0E4BE0 0000017DBD0F0AC0 0000017DBD0F0F20 win-wasapi.dll!WASAPISource::OnSampleReady+0x19
000000253504F4B0 00007FFC2E5515AD 0000017DBD101410 0000017DBD0E4BE0 0000017DBD0E5D80 0000017DBD101410 win-wasapi.dll!WASAPISource::CallbackSampleReady::Invoke+0xd
000000253504F4E0 00007FFC5A02147D 0000017D00000001 0000017DBEBA9C70 0000000000000000 00007FFC61060DAA rtworkq.dll!0x7ffc5a02147d
000000253504F560 00007FFC61060EBC 0000017DBEBA9DF8 0000017FD282FF20 0000000000000000 0000017FDA26BED0 ntdll.dll!0x7ffc61060ebc
000000253504F5B0 00007FFC6109D566 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffc6109d566
000000253504F8B0 00007FFC60F57374 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffc60f57374
000000253504F8E0 00007FFC6109CC91 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffc6109cc91
All crash reports has traces of the Audio filters that uses NVIDIA acceleration. According to: https://obsproject.com/forum/threads/obs-crashing.183674/post-671891 and NVIDIA site, different video cards uses different SDK for Audio Effects that should be installed separately for each card. So, either do not use audio filters (NVIDIA accelerated, that has new implementation in new OBS) or try to update the mentioned SDK libs and maybe contact NVIDIA support for details.
Dr2co
Thx Bro.
I'll check this point.
