OBS cannot capture frames generated by frame generation technologies
hikari5234
"OBS cannot capture frames generated by frame generation technologies. For example, when DLSS Frame Generation or FSR Frame Generation is enabled in a game, OBS only records the original frames and misses the AI-generated interpolated frames. However, NVIDIA's built-in recording software (like NVIDIA ShadowPlay) successfully captures these generated frames. Is there any way to fix this issue? How can I configure OBS to record the additional frames produced by frame generation tech in games?
Note: I’m not a native English speaker, and this text was initially translated using AI. Apologies for any grammatical errors."
Ankyna
Same problem for me when streaming, only capture display seems to work but i dont want to use that during streaming, i hope we will got a fix for that, moving the camera look weird with this problem.
duplesis
OBS can’t capture DLSS/FSR frame generation because those frames are added after OBS hooks in. ShadowPlay works since it records at the driver level. For now, the only options are to disable frame generation when using OBS or use ShadowPlay instead.
