Question / Help No sound in PC from NDI Mac
andreigurgel
I am trying to get my Mic audio (Yeti Blue) from my Mac using OBS on Windows.
I use the NDI Scan to do it. It works using PC to PC or Mac to Mac, but not working using Mac to PC.
Does anyone know about it?
Thanks,
andreigurgel
It is possible, I do it regularly.
How do you do on the Mac side? It is probably a config issue. On NDI Scan I just select Desktop and No mute, since we have less options than in the Windows site (Where I can select the sound source).
Am I doing correctly? Thanks
I run a copy of OBS with the NDI plugin installed and add a Dedicated NDI filter to any audio source I want to send over the network. Works in any direction between Windows, Mac and Linux.
Sometimes sources don't immediately appear and one copy of OBS will need to be restarted. Sometimes I can get them to appear by adding a space to the end of the name of a dedicated NDI source and then deleting it-- it doesn't actually change the name of the source, but seems to force an update of the available sources on other clients on the network.
All hail Stuart Cheshire!
