Question / Help No Keyframe rate adjust?
I do not see the option to alter this. When I stream to Twitch it tells me mine is 3.9 or 4 and should be changed to 2. I also noticed that after about 10 minutes even with OBS saying I'm streaming if I refresh my Twitch dashboard it will say I'm offline. I have noticed these issues recently. I don't know how far back they go so I'll just post the logs from the past few streams I did (or at least attempted to do).
  • 2015-03-02 09-22-07.txt
  • 2015-03-06 14-26-16.txt
  • 2015-03-06 14-23-02.txt
  • 2015-03-02 09-30-10.txt
  • 2015-03-06 15-50-39.txt
  • 2015-03-06 13-53-27.txt
  • 2015-03-05 13-03-58.txt
  • 2015-03-03 17-29-05.txt
  • 2015-03-02 03-51-54.txt
  • 2015-03-02 08-47-46.txt
I don't see that option in 0.8.3 when I go to settings -> Output -> advanced.
After messing around a bit more I found what you meant. Alright. Thanks for the help!
Gol D. Ace
OBS MP should adjust your Keyframe Interval automatically when you select Twitch as Service.
fps_num: 60
keyint: 120
You stream with 60 FPS per seconds. So a keyint of 120 means you get a keyframe every 2 seconds.
So your keyframe settings should be fine.
Lain
Forum Admin
Lain
Forum Moderator
Developer
Any remaining issues should be fixed in the next version, but yea it generally sets this stuff automatically otherwise.
Just uploading some logs from streaming today due to having more of these issues with my stream ending while OBS claims I am still streaming then OBS stating invalid stream key mid stream, ect.
  • 2015-03-12 12-26-06.txt
