No audio in stream
sabo__x
Howdy. I just got an old Elgato HD60 capture card. I'm streaming through obs with the capture card, chat link cable, and an external mic. I'm having some issues setting up this capture card. Video is perfect, the audio is the issue, as I have no game sound or party chat coming through on twitch stream from ps5. I went to Game Capture HD and set the audio to analog and the audio mixer is showing the capture card is picking up sound. Here is the log from my latest stream
Check your audio setting under the advanced setting and make sure audio monitoring is set to 'monitor and output'
sabo__x
It is set to monitor and output :( Does it need to be on a certain track? It's set to all of them right now. Someone also told me I needed to go into sound settings and listen to device, but I can't find that option either
Check the sound setting on your machine to make sure it's has the system output as the destination. I've had a similar issue on windows a while ago, I'm on Mac M1 currently so can't help you check.
sabo__x
My sound settings are showing output as "Elgato Sound Capture"
