No audio from Voicemeeter
17bishop
I dont mess with my OBS settings often, if at all. It worked about a month ago without issues. I rolled by GPU drivers thinking that might be the issue, but it was not. The major problem might be that Windows update forced me to upgrade to Voicemeeter 3.1.1.9 for driver stability or something. I'm at my whits end with this. I've even tried to route the audio through my standard output for Windows without any Voicemeeter interference, but it still did nothing. The meters on OBS didnt budge at all. My microphone does function normally and it also gets routed through Voicemeeter, so I'm really confused on why my outputs are not being captured. Any help would be appreciated. If you need more info, I will try my best to respond as quickly as I can.
  • 2025-08-21 15-21-43.txt
Herodotus
I FIGURED IT OUT! For anyone with the same issue in the future, VoiceMeeter's VAIO driver has a (new?) setting called "Enable Loopback Streaming" that's disabled by default. It looks like it needs to be enabled in order for any program besides VoiceMeeter to have access to the VAIO Input devices.
Go here: C:\Program Files\VB\VBVoicemeeterVAIOs
Run "VBVoicemeeterVAIO_ControlPanel.exe" as an admin
Check "Enable Loopback Streaming"
Reboot your PC
Thanks!
