No Audio capture
adva
Hi there,
since a few days I got problems capturing my audio. Neither desktop audio nor any mics are captured. I use voicemeeter as a virtual mixing tool. No updates in OBS were made and from one to another date I couldn't get any audio to my records or streams. Any drivers are up to date. The mics and sharing desktop audio works when using a video call but don't work if I want to capture them in OBS.
Already reinstalled OBS and set back to default with no results.
Anyone got a clue what I can do or fix?
Thanks for your help.
Herodotus
The mic might be a privacy setting thing.
This fixed the output capture issue for me though:
I FIGURED IT OUT! For anyone with the same issue in the future, VoiceMeeter's VAIO driver has a (new?) setting called "Enable Loopback Streaming" that's disabled by default. It looks like it needs to be enabled in order for any program besides VoiceMeeter to have access to the VAIO Input devices.
Go here: C:\Program Files\VB\VBVoicemeeterVAIOs
Run "VBVoicemeeterVAIO_ControlPanel.exe" as an admin
Check "Enable Loopback Streaming"
Reboot your PC
Thanks!
