Question / Help NightDev
Lyndon
Hi am trying to get NightDev working on OBS 0.10.1 but when ive install NightDev the source tab that ment to be added isnt showing CLR Browser is there anyway round this is or do i need to manually install the plugin and now use the auto install
Lyndon
Ive try using OBS-MP and am still getting the same error, ive upload a photo and yes i try install where it ask hehe. dont know whats going wrong
Lyndon
Ok not to sound like keeping on would you know witch files i need to manually install? and thanks for the help :)
dodgepong
Administrator
Community Helper
Wait, backing up...are you trying to use the original OBS or OBS Multiplatform? Because you posted in the OBS Multiplatform section, but you may have done so by mistake.
Lyndon
Am using OBS - MP but thanks to Harold have been able to get it working just use the link he put in and not used the install from NightDev just used there website for the URL
