I have a 9700xt
in obs i set CBR with 0 key frames and quality and 40000 bit rate, and it jumps all over whe ni drop into warzone while i am streaming, and the vide oquality is not so great. Is there support to use the dual encoders on the 9070 xt?
Anyone know how to stablize the bit rate, and make this usable on youtube at high bit rates? the s265 look bad at 49000 cbr.
also i am at 1440p. The other problem i have is when recording with obs, if i use cqp and select any number, using av1, the file sizes are enormous.. not matter that setting i use...
Hexfix93
Hexfix93
