Question / Help NEED HELP
imu03
I've used OBS to always stream, then 3 months ago OBS randomly kept crashing and never even let me reopen it again. When I restart my PC, it opens up and it says that it has sent the crash report to the clipboard.
I downloaded Streamlabs OBS to see if it wouldn't crash, and everything was going good until I added a "donation goal" tab and then it crashed.
I re downloaded all my graphics card drivers, updated my pc, and have done everything to make obs work and it wont. PLEASE HELP ME, I would really appreciate it
Here is the crash log:
  • Crash 2019-12-20 20-52-31.txt
Sukiyucky
I've noticed a lot of reported crashes of late in libcef.dll from calls made using the browser. I would suggest uninstalling your current 24 version and install 23.2.1 to see if that works and at least get you back up and running.
Make sure you come back to this thread and post whether it worked or not. In addition, change the topic from Question/Help to Bug Report so that the developers will be aware.
Also, be aware that we do not support StreamLabs (SLOBS) here.
