Need help figuring out what's causing OBS to crash
anthony_xdl
It only started recently and I had assumed it was because of the OBS update, but I reverted back to 31.0.0 and still had the same crash issues. It happens mostly while playing Marvel Rivals, but has also occurred while playing less graphic intense games. Today I started OBS and the camera froze, tried to open the properties and that also caused it to crash.
I looked at the log as best as I could, not really familiar with them... deleted some plugins I don't use, but can't figure out what else needs to either be deleted or added. I did change encoding to x264 from AMD HW 264 recently after reading that it might not be as good as x264....could that be the issue?? Any help would be appreciated! Thanks in advance!
AMD Ryzen 9 7900X
AMD Radeon 6800XT
32GB DDR5 G Skill RAM
3TB SSD
  • Crash 2025-03-16 17-15-35.txt
  • Crash 2025-03-16 23-25-27.txt
  • Crash 2025-03-18 17-53-17.txt
  • Crash 2025-03-18 19-53-55.txt
  • Crash 2025-03-18 20-25-17.txt
  • Crash 2025-03-18 21-36-11.txt
