NEED HELP!! error ‘Couldnt Access Channel or Stream Key’ is constantly ending my streams!
mblzed
for some reason each time im streaming my game or anything, after about 5 or so minutes of streaming, my stream completely shuts down and pops an error message saying 'Could not access the specified channel or stream key' and ive tried resetting the stream key, even tried linking my twitch acct and nothing, even enabled the network optimizations and nada, ive tried everything ive seen online and posting this is a last LAST ditch effort, i dunno what could be wrong and id appreciate some help! thank youu!!
heres the log
linkhs
I ran into the same issue while trying to stream tonight. After about 10 minutes of being live, I would see the message pictured below appear.
This happened after updating to 31.0.1. I have never encountered this error before on any version of OBS, and my internet connection is the same as always. I have been streaming using OBS and the same Twitch channel regularly since April 2024. I have attached the logs from my streaming tonight.
  • 2025-01-24 19-54-53.txt
  • 2025-01-24 20-10-01.txt
  • 2025-01-24 20-24-31.txt
  • 2025-01-24 20-25-29.txt
ciinTri
If you reset your stream key in Twitch Settings then click show, does it show up blank? If it is, the problem is on Twitch's side.
If it's on Twitch's side, it may or may not fix itself in a matter of few hours or even a day, to my experience.
mblzed
it didnt come out blank, ive reset it a couple times and it came out correctly, and i pasted it in there instead of using twitch acct connectivity and it still didnt work
mblzed
still no fixes for me yet..i only managed to delay how long it takes before it disconnects my stream, i really need some help lol
mblzed
i dont know how to read the logs, the most experience i have is reading MC Mod logs, so any help would be greatly appreciated
mblzed
any luck?
mblzed
so I just tried streaming to YouTube and did so successfully for over 3 hours at a time (havent streamed longer yet) but it worked on there, but Twitch still appears to have problems? it may be a bug with the new OBS update and Twitch? but im not sure, Twitch seemed to work weeks ago but this problem with it has been rlly recent and constantly reoccurring
so i still would like some help LOL!
ZVoss
Same exact thing is happening to me. Been through support with OBS and they said software is fine. Been through support with Twitch and they say its a connection issue on my end. I've reset stream keys, I've connected OBS to Twitch using the stream key method and the account method. I've tried different ingest points. Always the same result. Problem is I stream fine to Youtube and other platforms for hours with no issue. I can get disconnected from Twitch with that error message anywhere from 10 minutes to 1.5 hours into stream.
My first time encountering this error message was January 10th according to when I first asked my discord for assistance. Been happening every stream since. I was sick and not streaming for about 1 1/2 to 2 weeks in there but it happened yesterday. I streamed to YouTube today with no issues. I am on the latest OBS version, 31.0.1.
DraRex386
Problem could be the Coding of the program itself, is the Devs messed up somewhere in the code that they could miss and the compiler didn't catched on, i dont know alot of programing, but it my best explanation so far
iwillmameyou
I have also encountered this ever since I updated to OBS version 31.0.1. Its always 10-20 minutes into the start of stream I get the error message "Could not access the specified channel or stream key" as shown in reply #2. The only way I can get stream started again is by closing and reopening OBS a few times, or fully disconnecting and reconnecting my twitch stream key. I have tried all of the same things as reply #10 and have had no luck. Its really been messing with my VODs and analytics having stream crash 2-3 times per live. Has anyone found a solution or should I just revert to an earlier OBS version and hope for the best?
GentlemanJ
Hi folks. I am having this issue. Not much to add other than. I was house sitting for 2 weeks. and I DJ on twitch same account but a different laptop. I was streaming daily before going to house sit, took the gaming laptop, streamed every day for 2 weeks, then Friday (It's now Sunday) had a DJ stream on other device. Came home the following day. Last night and today I have been trying to stream at home on the usual gaming laptop, and have had this error come up each time. So the only thing that had changed was the location, and in between attempts doing the stream to twitch on a different device. Now I have this error. I have also tried a couple of the fixes. Not sure I did the "Bind to IP" correctly but it didn't work so I put it back to default. I uninstalled and reinstalled OBS, didn't work. My stream goes live and viewable for anything from 30seconds to 25 minutes.
RichardK3
Same problem here with Restream. But I also experienced it with Youtube and Twitch.
Definitely a bug in OBS. If I open the stream settings and just add a space to the stream url, then hit OK, I can start the stream again. The stream settings haven't actually changed, so it's not a problem on the other end.
RichardK3
Ok, after the latest OBS update didn't fix this, I gave up and switched to Streamlabs OBS. With OBS, my stream had been going offline multiple times per day. It's been running flawlessly for over 24 hours with Streamlabs OBS. So I guess I'm done with original OBS.
ultra_artu
I just had the same issue happen to me, was happily streaming for about 5 hours and then all of a sudden and then the same message popped up out of nowhere, could not click on the "start streaming button" until I closed obs and reopened it this literally ruined a recording session for me, thanks OBS
I just updated it just now so I hope it will fix it but based off what I'm reading prob not.
@lex
Io ho lo stesso problema da 3 mesi, dopo un aggiornamento di OBS. Posso dire che il problema è di OBS, riscontro il problema sia su Twitch/Kick/youtube. Provato sia con account che rtmp. Per me è un grande problema, la mia connessione si resetta ogni 4 ore.
ultra_artu
I recently checked a while back after updating and my encoders a while back after the update and apparently they were old
SplashyGG
I tried to do it on SLOBS and got the same issues. This was months ago tho so maybe it’ll be different but I had uninstalled SLOBS cause I stopped using it , you recommend I try it again?
