Question / Help NDI Audio Jumps problem
Benjabill
Hi, everybody. My name is Benjamin from Chile.
I'm have a problem with NDI plugin for local recording and streaming.
Im using a dual pc:
1.- PC-GAMER for (Play and Record)
2.- PC-STREAM for (Stream and Record)
Tthe problem is the game record on Stream PC its jumping like this image (audio and video)
But my camera and mi mic (connected to stream pc) works great, not jumping. I think its something of buffering, a bad router (im using: TP link tl wr940n with Cat6 cables) or a bad configuration of router on windows. Really need help.
Here is my two logs: for the same capture and stream.
I really appreciate the help of Narcogen :)
  • GAMER PC - 2020-05-08 20-21-43.txt
  • STREAM PC - 2020-05-08 20-21-45.txt
20:33:47.260: adding 256 milliseconds of audio buffering, total audio buffering is now 298 milliseconds (source: NDI™ Source)
20:33:47.260:
21:22:43.160: Max audio buffering reached!
21:22:43.161: adding 661 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: NDI™ Source)
21:22:43.161:
Your streaming PC is having trouble getting the NDI feed from the gaming PC, and this is causing it to lag.
This could be due to your network, or due to CPU overload, or also due to the fact that you're running an older version of the OBS-NDI plugin on the gaming PC; you have plugin 4.9 and NDI runtime 4.5.1 on the stream PC, but 4.6 and 3.8 on the gaming PC.
20:21:44.969: [obs-ndi] hello ! (version 4.6.0)
20:21:44.969: [obs-ndi] Trying 'C:\Program Files\NewTek\NewTek NDI 3.8 Runtime\v3'
20:21:44.969: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NewTek NDI 3.8 Runtime/v3/Processing.NDI.Lib.x64.dll'
20:21:44.973: [obs-ndi] NDI runtime loaded successfully
20:21:44.976: [obs-ndi] NDI library initialized successfully (NDI SDK WIN64 18:40:40 May 10 2019 3.8.2.0)
20:21:46.208: [obs-ndi] hello ! (version 4.9.0)
20:21:46.208: [obs-ndi] Trying 'C:\Program Files\NewTek\NDI 4 Runtime\v4'
20:21:46.209: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NDI 4 Runtime/v4/Processing.NDI.Lib.x64.dll'
20:21:46.240: [obs-ndi] NDI runtime loaded successfully
20:21:46.243: [obs-ndi] NDI library initialized successfully (NDI SDK WIN64 06:20:19 Apr 1 2020 4.5.1.0)
Benjabill
I Instaled the 4.9.0 on two computers and still having the jumps
and its no cpu because im monitoring on this recording
PC GAMER:
PC STREAM:
what i need to see on the network?
