LUA Comment Removal
LUA Comment Removal 0.2
DA_iNFAMOUS_DRE
I am sorry to hear that DA_iNFAMOUS_DRE, but let me see if I can help. If you have a moment, could you please help me by describing what obstacles or issues you encountered and I will do my best to help address and resolve them.
Hi, sorry for the late reply. I had deleted the files since i couldn't get it fixed, but i just redownloaded it and added it back to hopefully try to fix it. This is the error i get after adding them as scripts. The non edited version and the version after i put it through "Remove Comment".
[Find Source Location.lua] Error loading file: ...-plugins/frontend-tools/scripts/Find Source Location.lua:8: unexpected symbol near '<'
[Find Source Location no-comments (03.10.2022.14.49.40.957).lua] Error loading file: ...ource Location no-comments (03.10.2022.14.49.40.957).lua:7: unexpected symbol near '<'
Both are blank and don't display the options to find sources, saying "No Properties Availible". Also i'm on OBS 28.0.2. It used to work a few months ago, but stopped. I'm guessing it's a OBS 28.0 issue and broke like the pluggins broke for this update
GrumpyDog
I teseted and found an issue. Please see if the update resolves your issue.
DA_iNFAMOUS_DRE
Hi, thanks for your help, i added the updated remove-comments.lua but it's now giving me a similar error and shows no properties in OBS, it was at least giving me the option to use it in the previous version. I also noticed it with the Stop Watch Lua that was recently updated from you (that i just updated to now does the same thing)
I currently have 18 scripts & only these 3 produce this error, I’m also on OBS 28.0.3 if that matters / helps.
[Remove Comments.lua] Error loading file: ...a/obs-plugins/frontend-tools/scripts/Remove Comments.lua:8: unexpected symbol near '<'
[Stop Watch.lua] Error loading file: ...o/data/obs-plugins/frontend-tools/scripts/Stop Watch.lua:8: unexpected symbol near '<'
GrumpyDog
Try this, open the script in an editor and find the variable 'desc' and then directly after that on a new line, add the following line:
Lua:
desc  = ''
Alternatively, delete the content of 'desc'
Let's see if that fixes the issue.
DA_iNFAMOUS_DRE
Lua:
desc  = ''
Hi, I tried both methods but the same error still pops up
GrumpyDog
Okay, please take all 3 files you use that gives you the errors, zip them and attach them in here or in a DM.
Also, can you please let me know what OS version you use.
DA_iNFAMOUS_DRE
Hi, yes here are the 3 scripts. Also, I'm on Windows 11.
  • Scripts.zip
GrumpyDog
None of the files contained in this zip file are valid LUA Script Files.
You need to hit the "RAW" button and then right click and then save as with extenstion ".lua"
See this for help
DA_iNFAMOUS_DRE
See this for help
Thank you so much for your help, that fixed all of them. I was right clicking and saving them when updating all my plugins. I forgot i had to save them by going to raw first!
Timboxyz
Since this does not provide any OBS functionality, is this supposed to be run outside of OBS, in which case the built in Lua interpreter won't be available and so an external Lua interpreter will also need installing?
Timboxyz
I ask this because trying to add it in OBS causes OBS to exit immediately with no clue in the log
