Question / Help Looking For Help/Feedback With Settings
GameSpeakr
Ok so, in the last few days my OBS has started MASSIVELY dropping FPS on MOST games I play/ try to stream, frames seem to be 100% fine in this scenario.
Currently I have no idea how or what is happening, but after taking a look at it I have noted that even in the lowest of settings it still cannot maintain 60fps on affected games. (examples are R6:siege, Dauntless).
Now my PC is no pushover in fact here are the stats for it:
Intel i7 4820k 3.7ghz
Gigabyte Gforce Nvidia GTX 860 4GB
16GB DDR 3
Asus x79 Sabretooth MB
Can anyone provide a hand or an obs settings template I can use to get this to work?
Also posted is a log file I took from a gaming session today.
Any help would be majorly appreciated.
Also a note:
Full system cleanup done
Drivers ARE up to date
When playing have both process priority in obs AND task manager at high
Have run disk checks
Have run cpu, mem and gpu checks all are fine
EDIT: have included dxdiag stuff as a just in case
  • 2017-12-03 12-24-37.txt
  • DxDiag.txt
