Question / Help Keep getting dropped frames/weird fluctuation in bitrate...
mdb89
Hi. This is my first time on the forums. So I usually stream on Twitch with a bitrate of 3500 & had zero issues with that bitrate. Over the past few days, however, I'm getting dropped frames & a weird fluctuation in bitrate. I've tried everything in that troubleshooting guide for this issue. Nothing seems to fix the issue I'm having. I usually get a steady upload speed of 10-11 mbps, but I'm only getting anywhere between 6-8 mbps & when I run a bandwidth test with the TwitchTest program I get really low results. A technician was out to my place yesterday to look into the issue & he said I was getting 10-11 mbps upload, which is normal. I did another speed test later in the day & got a low result again. Also I tested out bitrates set to 500/1000/1500/2000/2500/3000, but still keep getting dropped frames/weird bitrate fluctuations. I'll attach the last log file to this post, as well as screenshots of a speed test & bandwidth test. Thank you.
https://obsproject.com/logs/PryCRvXhWBBv975j
