Issues with Frame Skipping and dropping
UltimoFive
Recently within the past couple weeks I have been losing frames and having frame issues. While checking the logs it said that my CPU overloaded 1.3% and then I fiddled around with it. Now it is skipping a little less, but isn't showing that it is overloading. I changed nothing in my settings before this started happening.
Probably good to mention that the dropped frames are only noticeable after recording, and I don't notice it during gameplay/recording sessions.
Specs:
GPU - GeForce RTX 2060 SUPER
CPU - Intel Core i7-10700 @ 2.90 GHz
Memory - 32Gb
Monitor Res- 1440p and 1080p
Log before I fiddled around: Is attached at the bottom.
Latest Log File: https://obsproject.com/logs/WfnryP3IqlYAGuGV
  • 2021-03-10 13-44-50.txt
