I need to stream a Tournament tomorrow and OBS won't work! Please Help quickly <3
Daniel_Zocker
Hello beloved OBS Community.
I've been a user of OBS for years and I have never encountered a crash luckily.
Well my luck has run out and that in the worst possible timing.
I have to stream a tournament for my school tomorrow and OBS Crashed on every occassion, so I'm seeking out help, hoping for some answers.
My crash report has been attached. I am using a DELL XPS 9520 (2022 Edition) with a Core i7-12700H - 32GB Ram - RTX 3050
Thank you infinitely for any advice and help in advance.
Love from Austria
Dan
  • Crash 2025-03-03 08-06-57.txt
Suslik V
Thread 5564: (Crashed)
000000F2275DFB00 00007FF859C24427 0000000000000000 00007FF8D95FEB3B 0000025ED5E795D0 0000000000000000 libmmdevice_plugin.dll!0x7ff859c24427
000000F2275DFC60 00007FF84F3CEC76 0000025ED5E795D0 0000000000000000 0000000000000000 0000025ED5E795D0 libvlccore.dll!0x7ff84f3cec76
000000F2275DFCA0 00007FF8D95FF0AD 00007FF8D965E500 0000025ED5E795D0 0000000000000000 0000000000000000 msvcrt.dll!0x7ff8d95ff0ad
000000F2275DFCD0 00007FF8D95FF17C 0000000000000000 0000000000000000 0000000000000000 0000000000000000 msvcrt.dll!0x7ff8d95ff17c
000000F2275DFD00 00007FF8DA9FE8D7 0000000000000000 0000000000000000 000004F0FFFFFB30 000004D0FFFFFB30 kernel32.dll!0x7ff8da9fe8d7
000000F2275DFD30 00007FF8DB5FBF2C 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff8db5fbf2c
The crash involves the "libmmdevice_plugin.dll" plugin from the VLC Player you have installed in your PC. Consider to install more stable version of the VLC Player (downgrade also an option). Or try to not use VLC player based sources in OBS. If VLC player works for you without mentioned plugin - you may try to delete this plugin from VLC manually.
Daniel_Zocker
I have now installed a older version from 2020 and it seems to be working now!
Thank you so much for your (very quick :) help!
I hope you have a wonderful rest of your day, and thanks for setting me back on track <3
SlavinJJ
I advise you to visit this site https://perabet-tr11.com/ where you will find a lot of interesting and fun community! As well as prizes and rewards for winning! I play often, and I have never regretted it.
It looks like the problem is really in the libmmdevice_plugin.dll plugin. Perhaps you should try updating VLC or using a different plugin for OBS.
