I need help with a problem: some fast frames that split when recording
isra1shot1kill
This is an example, when i turn the camera, in some frames this happen, idk why only when im recording with the ps5, not sure if its all about the capture device or the configuration i have.
In the second example is more clear, look at the log its like its split in this frame.
This is the actual configuration i have:
And in some post i see that they upload their logs, so this is mine, and also if anyone can help me setup the configuration to the best my pc can handle i be very greatful, i dont understand a lot of the settings i copy that from a video, and sorry for my english thanks a lot!
  • 2022-04-21 22-27-51.txt
It's recommended to use CQP instead of cbr.
Then adjust the CQ level to what your computer allows you. A level between 15 and 23. The lower value, better quality.
Max b frames at 4. Keyframe 0 (auto)
If you don't know what you're doing, don't use any custom codec configuration.
Also, take a look at the analizer
