I need help please.
wtwar
Harold
the log you provided was not from a session of OBS where you were streaming
speedtest.net test results do not test in ways that are comparable to streaming.
wtwar
here's all the logs in the log folder, The log I provided earlier were the last log I made.
regarding the speedtest I did tried downlading from different websites, it is as fast as it should but when i stream its another story
  • 2023-10-21 22-38-44.txt
  • 2023-10-22 17-07-17.txt
  • 2023-10-22 21-07-47.txt
  • 2023-10-22 21-14-11.txt
  • 2023-10-23 19-47-39.txt
  • 2023-10-23 20-53-32.txt
  • 2023-10-23 20-57-30.txt
  • 2023-10-23 21-18-09.txt
  • 2023-10-23 21-30-49.txt
  • 2023-10-23 22-30-42.txt
wtwar
downloading from websites also doesn't compare to streaming either.
Tried all the pinned topics related to my issue before creating this thread, none of the fixes worked.
forgot to mention, I did tested my uploading not just downloading, my connection itself is not the case, Had the same issue when I tried to stream from another location..
