Hide a Szene without deleting it
renthner
Hey there,
I want to hide a scene without deleting it, because there are filters on several scenes but i don't use them alone. Just in comparison with other scenes.
And for a better Overview I want to hide the scenes I don't want to see.
Is there a way to do this?
Greetings
Daniel
If you have template scenes you use only to include it into other scenes, replaces these scenes with groups. Include the sources in your template scene in one group and include this group in every scene you want to show them up. Afterwards, you can remove your template scene. Any filters you attached to the scene, you can attach to the group instead.
renthner
Thanks man, this helped me a lot! You're georgous!
/closed
