TheLuka
Hello! ive been having this issue for YEARS now, this issue affected my youtube career.
So i bought this Microphone Fifine AmpliGame AM8, its USB microphone
Here's amazon link https://www.amazon.com/FIFINE-Microphone-Headphones-YouTube-AmpliGame-AM8/dp/B0BMFQP2ZZ
I plugged it on my laptop: Acer nitro 5, Model: Nitro AN515-58
And it had weird crackling sound, but i fixed it by turning off audio enchantments.
but now it got a good sound but it cuts in and out in random times.
Heres exapmles:
I try changing sample rate (Hz) for the microphone still doesnt works.
I then tried the microphone on my old HP laptop,
and surprisingly, it works perfectly there without any issues.
weird thing is that when i plugged it in my old laptop the audio enchantment feature was not there.
Here are pictures of the USB ports for both laptops:
Screenshots of Both Laptops’ Device Manager Lists:
its really weird, microphone is normal in audacity and any other application.
Log file: https://obsproject.com/logs/ad6vTUfTjcmHSmyX
Things I Tried & More Info:
* My mic is Fifine ampligame am8.
* I am on Laptop (Acer nitro 5).
* I Dont use Usb hub or anything like that.
* The CPU isn't under a heavy load during my streams/recordings. The issue persists even if no game is running.
* I've recorded using hardware AND software encoding.
* Problem is in both broadcasts and recordings.
* I've recorded in Audacity at the same time as OBS to confirm that the cutouts only happen in OBS recordings, so it doesn't seem like a hardware issue.
* The sample rate for all audio devices has been set to 44.1khz, which matches my OBS settings.
* I've tested the mic with filters and without.
* The gain knob on my mic is pretty low. It's definitely not peaking unless I shout into it point-blank.
* I've tried running Streamlabs as administrator.
* There doesn't seem to be any correlation with my speaking volume or keyboard/mouse inputs.
* I've tried using OBS as well as SLOBS. No discernable difference.
* I've tried "Exclusive Mode" on and off under Windows sound settings.
* No discernable difference when I change the audio bitrate.
* disabled "allow the computer to turn off this device to save power" in device manager
I dont know what to do, Any help would be greatly appreciated! Thank you!
Leyth
WTF I'm literally having the same issue, on the same mic, on the same laptop, idk if it's a corrupt copy of the mic or if it's software. You know the fix yet?
Leyth
i have finally found a fix bro, go to device manager and open sound video and game controllers then find intel smart sound technology for USB Audio and disable it then reboot
Freddy2000
I just want to take the time to thank you for posting this. I've spent the past 2 full days trying to fix my USB microphone clicking sound, to no success. I was giving up and then thought to do one last google search....and then you came up :) Problem solved
Sepheras
You are my hero. OBS kept down sampling my microphone to 44.1khz while everything else was set to 48khz. This caused a mismatch of sample rate, and that caused popping and stuttering in my recordings. I spent dozens of hours reading articles and boards like this, watching videos, and taking solutions from ChatGPT to solve this. The only thing that worked was your solution right here. Thank you so much!!
