Having Issue in Streaming with pixelated quality on youtube.....
Noobie1303
My Current Setup is:
Processor: Ryzen 9 3900xt GPU: AMD RX 6600 Asus Dual RAM: 32GB(8x4) 3200 MHz XPG Adata Gammix Monitor 1: Acer VG240YS 165 Hz IPS 24 Inch Monitor 2: LG 22MP68VQ 21 Inch IPS 75Hz
And I'm Having issue with my Streaming on YouTube
YouTube Link: https://youtube.com/live/xS6vcPhaJCM
Please help me to get a batter quality stream. please can anyone find out the issue and help me? I'll be really thankfull to him/her.
  • 2023-09-24 19-35-49.txt
sandrix
There is no longer a need to use HLS for HEVC on YouTube, so you can leave RTMP
Bottom line, your stream should run in 2K on YouTube, no matter what resolution is set in OBS
Noobie1303
can you please give me all the settings details..... like
Which Encoder Should i use what should be the settings..... I need it more explained way. I'm new to streaming.
I Searched the internet and tried to copy tons of different settings but i could not get that high quality non blury and non pixelated stream. so please help me....
or should i purchase a RTX 2080 for better encoder.....
Run the Auto-configuration Wizard (tools menu) and apply the settings it gives. Do NOT change anything.
Restart OBS (very important)
Test it as is.
Done
sandrix
Unfortunately I don't have a manual in English. This is what I can offer you
If you seriously decide to stream, then you should think about an NVIDIA video card. Just think if it's worth it.
Noobie1303
Should i buy a RTX 2080.... i can get a pre owned card for very cheap..... It is cheaper than the actual price of RX 6600 which i bought..... so should i go for it...
sandrix
The RTX 2080 is about the same in terms of performance, but will provide much higher quality for streaming. So yes, it is a good option. But be sure to check its condition and temperatures, since the video card itself is quite old. Great RTX 3060 Ti option.
