Question / Help Hall / Echo When Recording External Mic Only in OBS
nue2lax
I have a strange problem with OBS. I'm trying to record from webcam and an external microphone. I noticed that recording the external mic in OBS creates a pronounced hall effect.
Recording the same source in Adobe Audition does not create that hall effect.
I went through all the settings in Advanced Audio Settings and also turned off all other audio sources in OBS (I think). I also monitor the audio via closed headphones, so there's no audio loop.
Can anybody hint me in the right direction what else the issue could be?
My specs:
Windows 10 Pro
OBS 25.0.8
Zoom F4 Audio Interface USB
Rode NT1-A Mic with phantom power turned on
Microsoft Studio Webcam
Adobe Audition 2020
Thank you so much!
  • 2020-05-12 14-06-59.txt
