I use the snapcam for beauty filters but obs has no skin smoother I see... (I watched youtube videos on how to use it in obs hehe)Does OBS Studio have an Beauty Skin Filter?
omg waiting for it!I've created a Lua script de-blemishing filter. Just waiting for forum admin approval.
I would love to "Beta Test" this script/plugin. Can you DM me the details? Hope that doesn't break some arcane rule I'm not aware of.omg waiting for it!
Hi,I've created a Lua script de-blemishing filter. Just waiting for forum admin approval.
I know that @bfxdev did a free color skin shader, it is not submitted resource though, you need to download .hlsl and .lua from that repo.Hi @khaver !
I love your Deblemish script!
Are you currently working on any other scripts for OBS?
I have a suggestion for your collection of outstanding color correction scripts: a skin tone color adjustment script.
It would be incredible to have a script dedicated to skin tones that picks up the skin color, similar to Deblemish, and then adjusts the hue, saturation, exposure, contrast or even beter a RGB adjustment of the selected skin color.
Thank you for considering this!
Cheers,
hey sorry, i have questions. I downloaded this, i think i put this in my scripts folder it popped up but no "dialogue" prompts pop up. idk how to get this to work or install it properly. can you consider making a thread or idk telling me how to get this to work but explaining it step by step? like after i download and click on it it prompts me to open it with windows notes program which clearly isnt what we're going for. explain it to us like we're 5 years old maybe. Sorry i'm trying to learn but i'm at a loss cant figure this out.No and No. You can close the "run script" window and the filter will continue to operate. OBS should save all the settings for the filter if you shutdown OBS normally.
